Hey guys and Gals
Recently installed a QD Exhaust and remap but my Idle is running a little high. Is there an idle adjustment screw for this model and where would it be located. I have looked in the manual but can't seem to find anything on the subject.
Is it as simple as adjusting an idle adjustment screw?
Cheers Clay
On my 2015 the primary idle control is set in the ecu not by a screw. There is an idle map which is related to engine temperature.
I run a higher idle on track so I adjust that table, along with the temperature that the fan comes on at.
Hope this helps
Arron
I use EcuStudio, or your dealer should be able to correct it with thier Texa software. I'm not sure if Rexxer can do it or not with a custom map.
Happy to share my tables with you but you would require the ecu software
Reactions: Donsy
