1 - 12 of 12 Posts
Major issues today......
After having my bike tuned to perfection and it becoming a pleasure to ride suddenly today it is having major issues.
I was riding it around this afternoon and everything was great then suddenly the Speedo started giving false reading and the bike stalled.
I turned the key off and restarted it and off I went then it happened again. While riding it started to stall if I pull the clutch in the engine stays alive but when I go to release the clutch while still moving the the engine dies.
I had to restart the bike numerous times to cripple it home. Now the Speedo does not work at all and just reads zero. Everything else is working fine. No errors on screen and no warning lights but the bike just stalls while riding
I have just got the girl preforming so well and this happens Grrrrrrrr
Can anyone shed so light on this issue please....
Thank you in advance
Clay
Clutch in or stalling says to me have a look at the safety switch on the sidestand..
Reactions: george4337
have you added any aftermarket systems lately which required the battery to be disconnected? Maybe a Power Commander? You may have a bad ground. Remove the battery cables and clean them then secure them.
Location of Speedometer Sensor in 2013 F4 1000
Can anyone tell or show me where the speedo sensor os on my 2013 F41000 as I am have issues with my speedo.
Thank you
Clay.
It's in the workshop manual Clay, electrical section fault finding has a good testing procedure. It's at the rear wheel, behind the brake disc. Check that and sidestand and clutch switches.
Thank you Donsy
I just wasn't sure whether the sensor was on the front wheel or the rear wheel.
I only have the MY10 Manual but own a MY13 F4 and having issues downloading that manual
Cheers Clay
@Clayton1001 - Check the notification at the second from top of this section, it's a "sticky" with a red exclamation mark next to it mate, go the my last post in that notice - Maintenance & Tech. Issues (All 4 Cyl. Models) - MVAgusta.net
Also read the "Announcement" right at the top called "Read the Please RE MV Manuals"
And there's two here, in the sticky second from the top in your model section - http://www.mvagusta.net/forum/106-f4-2nd-gen-2010/85930-workshop-manuals-most-mvs-all-use-2.html
Clay
Clay...Check your battery leads are not loose.
I had major probs like yours and after going up down and round it sideways, I discovered my earth lead was loose.
Hope you find it
Joe
Hey Guys
Thank you for your imput
Update.... I have discounted the rear Speedo/ABS Sensor and all issues have stopped except the speedo not working of course. I will replace the sensor and hope that that is the fix for my issues,
From what I can tell, the sensor is faulty and grounding out and cause my bike to stall. The stalling has stopped now I have disconnected the sensor.
i will update again when I have further results
1 - 12 of 12 Posts
