Hi all! 👋
A little over a year and a half ago I got myself a 2012 F41000RR with ~3500 miles on it. The second time I started it up and took it for a ride (the same day I took it home) the bike started stalling as soon as I would let the clutch out as if there was no bite point - just on or off. I called the dealer and they picked up the bike, looked it over, said they couldn't find the problem so they'd order and install a new clutch free of charge. I got it back a couple of weeks later and all seemed well.
I've since put ~4500 miles on that clutch (currently 8662mi), and now I'm having a new problem. The other day I was stopped for gas and upon starting the bike up again I noticed some significant clutch creep and it was basically impossible to get into neutral with the engine on at a stop. Took it home and put it on rear stand: clutch lever pulled in 1st-6th gear and the wheel spins same as if it's in gear and would stall out in 6th if I applied the rear brake.
A few things to note:
The clutch lever feels great and I don't see leaks anywhere. A buddy and I pulled off the clutch cover. FYI to others in case you run into this - none of my 8mm sockets were able to access the leftmost cover bolt until we took off some of the perimeter of the socket with a grinder :/
We took a video hoping someone might be able to spot a problem at a glance. I can't find any measurements with respect to clutch travel in the manuals I've found online, but it appears the clutch is extending out far enough. We also noted some scoring on the perimeter of the pressure plate (see picture below) - not sure if that's poor manufacturing or a problem.
I'm picking up some tools today to remove the pressure plate to inspect the disks/friction surfaces. I'll post an update if I can get to em. Did notice that when releasing the clutch they don't seem to separate at all - used a screwdriver to gently separate some disks, but still extremely hard to turn the rear wheel by hand with the clutch in while in gear.
I have an appt scheduled with the dealership a couple of weeks out just in case I can't get to the bottom of this on my own. Sorry for the long post, but any help would be much appreciated.
I'm considering swapping out the entire clutch assembly so any recommendations are also appreciated. I'd almost prefer a non-slipper clutch just to reduce complexity - I'm not a racer so don't really need it, and the slipper clutch on this bike is not great. I have to feather it to get her going - any slight amount of power on start and the bike bucks like crazy!!
Thanks again,
-Ian
- The bike had not been sitting for more than a month
- I did bleed the brakes/clutch before this started happening.
- Also, I usually only pull the clutch lever in about a quarter of the way on upshifts, but always all the way in on downshifts.
- The bike runs pretty hot despite replacing coolant recently. I live in Texas and it's almost always 1 or 2 bars above "normal"
- Re-bled (both top and bottom bleed nipples) at least 5 times - no change
- Tried unsticking the clutch while parked and revving in 1st/2nd
- Pulled off and visually inspected slave cylinder - no noticeable leaks and the cylinder/clutch control rod looked clean and undamaged
- No noticeable leakage/damage at clutch master cylinder
- Pour fresh oil over clutch pack (pic of oil I used below)
Thanks again,
-Ian
