I wish to install racing clipons what are my options folks?
I would like to open the angle a little and the standard ones are fixed in one position so original will not do. What do people use for racing?
Thanks,
Chris
Hi Arron!
I have a feeling the 2012 form diameter might be 56mm but will have to check.
Thanks a lot!
Chris
Just remove the locater pin on the bottom top of the stock clipons and you can rotate them to a different position. There is not a lot of room to move them without hitting the fairings no matter what you buy.
Hi Arron,
I got the clipons, they are very good and the company seems very professional. Can't quite do a full lock as they are slightly lowering the height of the bars, did you have the same issue?
Thanks,
Chris
