Gents,
I'm close to having my 2010 put together and need some help with the dual side stand spring arrangement. Mine was missing the stand and springs when I purchased it and I would appreciate the help fitting them up correctly.
Thanks.
Fairly easy. Download the parts list and you should see a blowup of how it is arranged. I used a big channel lock to pull them on when I swapped sidestands. If I remember correctly, one hook in and one out, just like the exhaust springs.
The number 22 bracket just slips over the pin that is above the side stand nut then that is held on by the springs.
Thanks, thats the part I'm missing. It fits over the pin on the back side of the sidestand braket? It must pivot along with the sidestand motion using spring tension.
Thanks again for your time.
