Having trouble replacing my 2000 F4 750 top radiator - it's corroded, has a bodged repair and the fins are not letting much through.
I've read a lot of threads on replacement.
Would this https://www.ebay.com/itm/MV-Agusta-F4-1000R-1000RR-1000S-1000-1000RC-2010-2016-Water-Radiator-8000B3422/282990452266?hash=item41e38b9e2a:g:BT8AAOSwYf9bEQYL
From a 2010-> F4 1000 fit it's? I see there's a filler cap that would have to go into the air tube, but the hose stubs look to be in the right place...
Or do I just bite the bullet and blow £ on a recore?
I seem to recall some one (or 2) doing this....R1andrew maybe??? Do a search and with luck you may find something.
Ed;
It was gotojoe, he posted pictures
I had radiators modified for Donsy and myself with a cap on the right tank and a horizontally
split left tank way before the '10s came out......my way eliminates the crossover waterpipe
and depressurizes the header tank making it into gravity feed overflow tank
:wink2:
