*** SOLVED *** Culprit was a melted solenoid relay Connector ...
My 2010 990R wont start. When turning on the ignition the lights & dash come on, the pump primes and it wont start on the button. The battery is fully charged ..
I can hear a noise from the area of the box on the left (ECU?) - this video records the noise.
https://youtu.be/qTOxirhvjyI
Where do I go with this one guys ?
Also of note and possibly related is that there was a problem a while back where all electrics failed totally for a bit, as in when riding the bike one day it cut out totally, rolled on for a while with momentum but I managed to start it again with some frantic lever/button/key turning action. That might be related but it did start after that incident for a few weeks and its not been used since for about 3 months.
Could still be the battery, my 990r did the same thing a few years ago. Battery had full power with a voltmeter but had no current carrying ability. Press starter button and nothing. New battery and all good.
Download the manuals, have a read through them and familiarise yourself with your bike buddy. On a bike, as in cars etc, there is only one left side and this is determined when you sit on the bike.
Have a look under your seat if you don't have the melted starter solenoid connections which is a fairly common later model Brutale issue ( You will see more examples here in the Maintenance section and the Tech Tips section).
I'd replace the battery after checking all connections, that sound is much like a really not latching because of low Voltage.
OK - the solenoid connector is busted ... do I just pull the wires and fit into a new connector? Could water under the seat have caused this ?
In the meantime I'll check for any obvious cause. I already had issues with the clutch switch and the starter button .. bloody electrics!
This is a common occurrence on that particular connector. It is a high current draw and it tends to corrode over time. That connector, and your battery connections, should be periodically cleaned and treated with a grease specific to electrical connectors.
