1 - 13 of 13 Posts
Everything is good :D
You might only want to upgrade the rearhub bearing.
...it's often considered to be the epitome of the B4 (the most Brutale :) )
Oh yeah baby !
All the usual Brutale problems:- hub, headlight, gear spring, hair trigger throttle etc., etc.
But sort those, add a Microtec from Chris and what a fuckin' beast of a bike. A pleasure to commute, tour or fang. My Precious and I had to have it.
Deano
Yes ,spend a little extra on it ,or maybe a lot LOL . And it is worth every penny . And certainly the Daddy .
Now out of the box a good bike if you like a hard ride .
Rear hub changed the bearings at 22000 km .either replace with Mitchy hub or new bearings your call.
Actually i will stop here,How many KM OR MILES IS ON THE BIKE .
Then i can give you better common issues.
cheers eddy
None better (with a Microtec & HM quickshifter) it is better than the new Aprilia Tuono V4 Factory in my opinion. Yes I have owned both and still have the B4 1078RR, that should tell you a lot.
1 - 13 of 13 Posts
