61 - 62 of 62 Posts
The starter is very much like most other bikes out there. Pretty sure it is a Japanese product. If your dealer tech knows his stuff he can likely fix it with parts from a Japanese OEM. ....or even install a complete starter. Frequently the only difference is in the end cap that has the mounting tabs. Swap that part to the new starter and you are golden.
Reactions: Arnie
Not sure if it helps... I had similar issue with misfire at low rpm that would clear, or at least wasn't that noticeable at higher rpm.
Turned out to be a faulty coil pack sparking to the cylinder head instead of via the spark plug, at idle you can pull them out one at a time and see which one you can remove without the engine note changing.
61 - 62 of 62 Posts
