Presenting the new 2007 Victory Hammer S
The Hammer S is a new sportier Hammer. The blacked-out engine, handlebars, gauges and inverted forks tell you this is a machine that was built for performance. The red, powder-coated Gatlin wheels by Performance Machine and a custom-inspired headlight tell you it's also built to look good too.
Engine:
* Type: 4-stroke 50 degree V-Twin
* Displacement: 100 cu in / 1634cc
* Bore and Stroke: 101x102mm
* Fuel System: Electronic Fuel Injection with 44mm throttle bodies
* Compression Ratio: 9.8:1
* MPG: NA
Drivetrain:
* Transmission: 6-speed overdrive constant mesh
* Final Drive: Carbon fiber reinforced belt
Brakes:
* Front: Dual 300mm floating rotor with 4-piston caliper
* Rear: 300mm floating rotor with 2-piston caliper
Suspension:
* Front: Inverted cartridge telescopic fork, 43mm fork tube, 5.1in/130mm travel
* Rear: Single, mono-tube gas/forged and cast aluminum w/ rising-rate linkage swing-arm/3.9in. (100mm) travel/preload adjustable spring
Wheels and Tires:
* Front: 18x3 in wheel with 130/70R18 Dunlop Elite 3 tire
* Rear: 18x8.5 in wheel 250/40R18 Dunlop Elite 3 tire
Dimensions:
* Length: 92.7/2355 in/mm
* Seat Height: 26.4/669.3 in/mm
* Rake and Trail: 32.9 degrees /5.57/141.5 in/mm
* Wheelbase: 65.7/1668.8 in/mm
* Weight: 657/298.6 lbs/kg
* Fuel Capacity: 4.5/17.0 U.S. gallons/liters
Miscellaneous:
* Colors: Sunset Red and Black
* Price: $19,749, CA - $19,998
* Warranty: NA
Others in the 2007 lineup
Victory Hammer
Victory Vegas Jackpot
Victory Vegas 8 Ball
Victory Kingpin
Victory Ness Signature Series
Victory Kingpin Tour
source Victory Motorcycles
