1 - 9 of 9 Posts
Guys
I was at Donnington yesterday and biek was fine until last session when the dashboard started lighting up like a xmas tree, and the rev counter going beserk.
Engine was still runninmg fine though.. came into garage and dash was completely blank, not 1 light etc
Today i have checked fuses and have checked that i'm getting power on the dash conenctor :-
<12v over pins 9(IGN) & 20(Gnd)
<12v over pins 10(BATT) & 20 (Gnd)
Also the Power Relay is working fine.
Engine turns over and fule pump is alive.
Battery showing 13v
Is there anything else i need to check ?
I would have expected that having 12v on pins 9/20 and 10/20 would have been enough to at least light the lcd or backlight ??
If it is the dashboard, has anybody taken one apart to check solder joints etc ??
Have you disconnected, then reconnected the dash?
Sounds like a broken solder joint on the power supply
Not necessarily. Open it up and see what you see.
Well couldnt see anything obvious...
But took it completely apart - every screw removed and re-assembled...
And tested without the covers on... and blow me backwards it worked....
Replaced covers and still functioning.. crazy or what !!! :grin2::grin2::grin2:
Sometime, it's just a dirty connection.
Glad to be of service.
1 - 9 of 9 Posts
