Hello Friends,
I have seen lots of issues posted regarding the click sound when trying to crank up, and most people ending up buying new batteries.
Unfortunately, I am going through the same. But there is a confusion.
The first time I had this issue, I simply purchased a "Battery Maintainer" from Walmart, and left it on charge, and in the morning, Voila! it cranked up just fine. Took it out for ride, battery got charged, and took it out again the next day. Soon after, came the cold weather, couldn't dare to take it out, but felt worry-free as the maintainer was on, and the green light kept flashing; showing that battery is charged and its maintaining it.
And then, a couple of weeks ago, tried to to take it out, and Darn- The click sound again. And Mr. Maintainer was showing the green flashing light a moment before My failed try. Disconnected/reconnected and left it for charge over night, and the same issue next morning.
Decided to return the stupid maintainer and purchased a Die-Hard Charger/Engine Starter with 80 CCA. This is something fancy. The microprocessor first desulphates prior to charging. And behold, I got an error code on Mr. Bruce Willis. Consulted the manual, and the error code 'F02' shows that Mr. Willis failed to desulphate the battery and the battery is bad.
Unfortunately, I don't have slopes around here so that I could do the 2nd gear thing. The only option I have left is to use Mr. Willis as engine starter.
Finally, my question... would 80CCA suffice the start or will it be too much for the starter? I couldn't find out anywhere about the max input Amps for the starter on this F4. Don't want to damage the electrical system even though, they say to attach the black terminal somewhere on the frame and not the battery. Currently installed Yuasa shows google results of 190 CCA. So I think its safe?
Need your expert opinion before I screw my Black beauty up.
Thanks Guys.
Thanks Guys.
