1 - 1 of 1 Posts
Presenting the
2007 BUELL LIGHTNING SUPER TT XB12STT
Technical specifications :
  • 1203cc Thunderstorm V-Twin powertrain:
  • 88.9 mm bore and 96.8 mm stroke
  • 10.0:1 compression ratio
  • 49 mm down draft DDFI II fuel-injection
  • Interactive exhaust with mass-centralised mounting
  • 100 hp / 101.4 PS / 74.6 kw @ 6600 rpm (EU Standard EC95/1)
  • 81 ft. lbs. / 110 Nm peak torque @ 6000 rpm (EU Standard EC95/1)
  • Villain Black 6-spoke powdercoat cast aluminium wheels:
  • Front: 3.5 inch x 17 inch wheel with 120/70 ZR-17 tyre
  • Rear: 5.5 inch x 17 inch wheel with 180/55 ZR-17 tyre
  • Pirelli Scorpion Sync tyres
  • Buell ZTL front brake
  • 43 mm Showa fully-adjustable front suspension with inverted forks
  • Showa fully-adjustable rear suspension with coil-over monoshock with remote reservoir
  • Narrow Supermoto-style solo seat
  • Supermoto-inspired upper front fender design
  • Racing-style white Surlyn flyscreen and tail section number plates that are easily
  • swapped out as a canvass for moto art and self-expression
  • 798 mm seat height
  • Dry weight: 179 kg
  • Wheelbase: 1365 mm
  • Graphite Grey frame and swingarm
  • Supermoto-style handlebars with crossbar and deflectors.
1 - 1 of 1 Posts
