Thanks, I have his email address and will drop him a lineYou might also ask your fellow Manxman Ade for some help. He's a really good man and knows his stuff. These days into old Kawasaki triple 2-strokes, but he knows MV Agusta.
I have tried to do that but just get lost.....!I’m thinking that may be your best bet.
Before doing that though, trace through the electrical diagram to see where the ECU interfaces with the SPU
This statement does not makes sense. Please clarify.There is no power to the SPU fuse marked Latch Relay and although there is power to all fuses and fuses are good,
Hi Chuck I went to the fuses on the SPU. One fuse is marked "Latch Relay" and I tested to see if there was power to this fuse. There isn't, hope that makes sense. The pic in my first post shows the fuses, latch relay is 6th from left TaThis statement does not makes sense. Please clarify.
I believe the Safety Diodes are in, and part of, the ECU.
How are you testing voltage between those pins?
it is sounding more and more like ECU is the problem. Key on and in neutral but no latch relay power.Power only gets to the Latch Relay when the ECU satisfies its SafetySystem and provides a ground to the Primary Coil of the relay. Key on, switch in run, side stand up or bike not in gear or clutch lever pulled.
