I bought a low mileage 910 last September, it had not been used for a long time and needed a new battery. I stupidly put one of the negative wires to positive and my problems began. To cut a long story short, the starter solenoid is good and fuse is fine. I replaced the SPU with a brand new unit and the ECU has been checked over by Carmo Electronics and it is OK. There is no power to the SPU fuse marked Latch Relay and although there is power to all fuses and fuses are good, nothing controlled by the first 5 fuses on the left of the picture works. There is no local MV workshop and I am out of ideas. There is no diode on this model. Can anybody help please? Thanks
