1 - 1 of 1 Posts
Presenting The all new 2007 BMW R1200R
Specifications: R 1200 R.
Power Unit, Engine
Capacity cc 1,170
Bore/stroke mm 101/73
Max output kW/hp 80/109
at rpm 7,500
Max torque Nm/lb-ft 115/85
at rpm 6,000
Configuration Boxer
No of cylinders 2
Compression ratio/fuel grade 12.0/premium plus
Valve/gas control HC (high camshaft)
Valves per cylinder 4
Valve dia, intake/exhaust mm 36/31
Fuel supply Electronic intake manifold injection BMS-K
Emission management Fully controlled three-way catalytic converter
[It also has ABS and Optional Traction control]
Electrical System
Alternator W 600
Battery V/Ah 12/14 maintenance-free
Starter kW 1.2
Power Transmission/Gearbox
Clutch Single-plate dry clutch, dia 180 mm
Gearbox ***-shift six-speed gearbox
Primary transmission 1.882
Gear ratios I 2.277
II 1.583
III 1.259
IV 1.033
V 0.903
VI 0.805
Drive shaft
Final drive ratio 2.75
Suspension and Running Gear
Frame Tubular steel spaceframe, load-bearing engine
Suspension, front BMW Telelever
Suspension, rear BMW Paralever
Spring travel, front/rear mm 120/140
Castor mm 119.1
Wheelbase mm 1,495
Steering head angle ° 62.9
Brakes front Double disc brake, dia 320 mm
rear Single-disc brake, dia 265 mm
BMW Motorrad Integral ABS as an option
Wheels Cast wheels
front 3.50 x 17
rear 5.50 x 17
Tyres front 120/70-ZR 17
rear 180/55-ZR 17
Dimensions and weight
Length, overall mm 2,145
Width, overall, with mirrors mm 872
Seat height mm 800
Weight, dry kg 198
DIN unladen weight with full tank kg 223
Weight, max permissible kg 450
Tank capacity ltr 18
Performance
Fuel consumption
90 km/h ltr/100 km 4.1
120 km/h ltr/100 km 5.5
Acceleration
0-100 km/h sec 3.6
Top speed km/h 200 plus
Colours:
Colour Seat
R 1200 R Night Black non-metallic* Black
Crystal Grey metallic Black
Granite Grey metallic Black
*Also available with double decal lines in white as an optional extra.
source
1 - 1 of 1 Posts
