1 - 2 of 2 Posts
Presenting the
2007 BMW HP2 Megamoto
Make Model
BMW HP2 Megamoto
Year
2007
Engine
Four stroke, two cylinder horizontally opposed Boxer air/oil-cooled, 4 Valves per cylinder
Capacity
1170
Bore x Stroke
101 x 73 mm
Compression Ratio
11.0:1 Induction
BMS-K
Ignition / Starting
- / electric
Max Power
77 kW 105 hp @ 7000 rpm
Max Torque
115 Nm @ 5500 rpm
Transmission / Drive
6 Speed / shaft
Frame
Steel tubular spaceframe, non-load-bearing engineFront Suspension
45mm UPSD Gabe. 305mm wheel travel
Rear Suspension
BMW Paralever. 265mm wheel travel
Front Brakes
2x 304mm discs 4 piston calipers
Rear Brakes
Single 265mm disc 2 piston caliper
Front Tyre
120/70 ZR17
Rear Tyre
150/70 ZR17
Fuel Capacity
13 Litres
Didnt Santa Cruz BMW build one like this? Thought I saw it in a Rob Report Motorcycle ad.
1 - 2 of 2 Posts
