1 - 1 of 1 Posts
Presenting the..
2007 Aprilia RS 125 Lorenzo Rep
Make Model
Year
2007
Engine
Liquid cooled, single cylinder, two stroke
Capacity
125
Bore x Stroke
54 x 54.4 mm
Compression Ratio
12.5:1
Induction
Dell'Orto PHBH 28 BD
Ignition / Starting
Electronic with fixed spark advance CDI / electric
Max Power
34 hp- 24.8 kW @ 11250 rpm
Max Torque
20 Nm @ 10000 rpm
Transmission / Drive
6 Speed / chain
Frame
Cast aluminium, reinforced box section, sloping twin-spar frame.
Front Suspension
Upside down hydraulic fork, Ø 40 mm. 120mm wheel travel
Rear Suspension
Cast aluminium box section swingarm with asymmetric members. Hydraulic monoshock with adjustable spring preload. 120mm wheel travel
Front Brakes
Single 320mm disc 4 piston caliper
Rear Brakes
Single 220mm disc 2 piston caliper
Front Tyre
110/70-17
Rear Tyre
150/60-17
Seat Height
805 mm
Fuel Capacity
14. Litres
1 - 1 of 1 Posts
