1 - 9 of 9 Posts
Hi
The lean angle on my bike when parked is getting scary and seems to have gotten worse over the couple of years that I've had it.
Had a look at the side stand and noticed that there is lateral play/slop in the pivot/bush of the stand. Anybody had any experience with fixing this, apart from dishing out big bucks and waiting forever for a new part from MV?
Alternatively, any suggestions for an improved alternative? I'm thinking of adding a thicker/wider foot to the stock stand for less lean angle and bigger footprint.
Cheers Claudio
Discussion Starter · #3 ·
Ok, thanks for the tip, will check tomorrow
Discussion Starter · #5 ·
Hi Folks
Took the stand off the bike and all bolts had been securely fastened. However, the U-section at the top of the stand had widened due to a crack. The recessed bolt head only has a small lip and that had ceded into the recess allowing the U-section to widen and subsequently crack.
I took it to an engineer who closed/straightened the U-section and welded the crack. He then made me a new bolt with a wider head so as to prevent the U-section from widening in future. He also welded a thick foot/pad at the end of the stand.
cheers, Claudio
Claudio;
still be careful, the stand WAS probably heat treated....that's why they crack
now it isn't heat treated
:popcorn:
Hi
Cheers Claudio
Glad you got it sorted Claudio....., I 'improved' mine a while ago which might be of interest to you?.
http://www.mvagusta.net/forum/showthread.php?t=48005
Brian:)
1 - 9 of 9 Posts
