1 - 6 of 6 Posts
I've spent a bit of time looking at old threads regarding this issue, please don't flame me for asking for a bit of help and confirmation of the problem.
My bike has developed a habit of 'peeing' a bit of coolant from the overflow line, although it's not overheating (210F is the highest temp I've seen in stop and go or idling at a red light.) Concerned that the coolant level might be getting low I added about a pint to the bone-dry overflow reservoir; That resulted in a bigger puddle under the bike!
All I'm gathering from old threads is that there may be air in the system (never drained before, bike has ~6K miles) and the remedy is to drain and refill (according to the protocol explained.) Another cause could be the overflow container cap, i have the original one and it may be malfunctioning; There may be a revised pressure cap available.
Perhaps there is something else I may be overlooking, I'm getting an occasional drip onto the hot headers (smell & vapor.) Any advice on how to proceed with a fix will be very much appreciated!
I'm almost 'there' with this bike, having fixed the few other known issues (SPU, rear hub, etc) and I'm really enjoying it at long last! A Muzzy (metal) cooling fan has resided on my parts bin for quite a while, that's an upcoming project. But I'm now ready to do some 3-day tours on this Brutie and I worry about coolant levels and getting stranded, that comes first.
1 you have a leak......you need to pressurize the system to find it.......
Easier said than done because of the screw on cap......every asshole engineer has to
design a new radiator cap .......the SnapOn catalog posts 56 adapters......
There used to be 2 cars and trucks
Check with a local radiator shop to see if they have one that splices into a hose
That will also test the cap at the same time have them test for combustion gases in
the coolant.......it's just a chemical they add to some of your coolant
Let us know the results
:popcorn:
My 750 used to barf a bit of coolant once hot, but it would stop after about 3 or 4 times once it had found the right level (I learnt never to top it up over the lower mark).
If yours is doing it again and again then my first guess is the filler cap assuming you don't have a leak somewhere.
Both my Brutales run at the lower coolant level mark or will spit out from the overflow hose (common)but you shouldn`t be getting coolant on the headers unless overflow hose is split or as Noel said you have another leak somewhere
Thanks guys! I'll pressure check that cap & investigate the occasional drip. Sounds like the fluid-level marks on the overflow container are as useful as a posted speed limit on the Autobahn.
I have an 07 910s that did the same thing when I first picked it up. Once it got hot, it would dump coolant out of the overflow...not a huge amount but enough to get my spidey sense going! I also noticed it would make a kind of groaning noise while cooling down, like air bypassing a valve or something. I serviced it myself and noticed that the cap on the expansion tank was unbelievably tight - had to use vice grips and a rag to protect the plastic cap just to loosen the thing off...which of course required taking the fuel tank off too! I read a few threads which indicated that the coolant level should be kept at the lower level. Ran the bike with the cap off until hot and then just hand-tightened the cap and have had no problems since.
1 - 6 of 6 Posts
