1 - 1 of 1 Posts
10,700 miles. This may increase since I still ride the bike.
The bike is located in Connecticut.
This bike is in great condition save for a couple pits in the red paint on the trellis frame. As some of you may know, there's a common issue with the headlight lens adhesive failing. This has happened on my bike. The lens is fine and is currently wedged in place with the original bead of silicone and a few strategically placed strips of duct tape. I leave it up to you to come up with a more permanent solution.
I bought the bike in fall of last year and have put about 3,000 miles on it and have never experienced a technical issue. The engine and transmission run and shift flawlessly. A new battery was installed in October of 2013. The bike is mostly stock with a couple after market parts including a dyno-jet power commander. The catalytic converter has been removed and replaced with a straight mid-pipe from QD Exhaust. The exhaust headers and tail pipes are stock.
Click here for more pics
1 - 1 of 1 Posts
