1 - 9 of 9 Posts
Hello
First post and need some help. Recently wrecked 2006 910, frame torn and damaged right side motor mount. Looking to replace the frame but do not know what year frames will interchange ? Is the F4 frame the same too ?
Thank you
Basic frames are the same from first Brutale up to the 2009 I think. However there are geometry changes between 750 and 910/1078....and the 2007 (2008 USA) Euro3 spec bikes have some tabs and such for the second air system valves, ECM changes, etc.
I would think you could make a later frame work, but should probably try and find one for the pre-Euro3 910
Welcome to the forum mate.
If you get real desperate, then a F4 frame will work, the basic layout is similar, just the ancillary mounting tabs are different, in other words, where the relays mount, and also the F4 steering damper.
The engine and frame side plate mounts etc are the same.
1 - 9 of 9 Posts
