1 - 11 of 11 Posts
Hello All.
I have a blown head gasket on my 2002 F4 Senna. The manual refers to 3 that work for this bike but each have different thicknesses. Does anyone know which one I need?
Here are my options:
800098679 1.45mm
8A0098679 1.30mm
8B0098679 1.20mm
Cheers!
Thinnest one will increase compression the most and may need tuning. If you can't find the number, your safest bet is the middle.
I had a 312R I struggled to sort the oil leak on, the owners had severely overheated the bike several times.
In the end re-torquing the head was enough to sort that leak out. I also had to replace the cam cover gasket and all the o-rings, the one's around the spark plugs leaked too.
Cheers Donsy! I thought this was going to be a huge problem but it seems it wont be that bad after all. I have just been so busy with work and haven't had much time to look at it.
1 - 11 of 11 Posts
