Have questions about the belly pan installation on a 2013 Brutale 1090RR. Pan came with 2 brackets and 2 spacers, had to source the bolts, not a big deal but a bit of a hassle. Anyhow, I think I figured out where the mounting brackets go. The "narrow" one appears to go behind the kick stand mount, the bolt openings on the bracket line up. This leaves the "wide" one for the right side, most likely mounted between the block and the rear brake master. However,there are three bolts around the rear brake master and only 2 openings on the bracket. Am I looking at the proper position to mount the bracket? Don't want to go around undoing bunch of bolts for no good reason.
Also, with the belly pan do I need to retain the right exhaust shield in the picture? the bolt mount welded to the catalytic converter broke loose so the shield is hanging by one bolt. it will most likely touch the inside of the belly pan, so can I just remove it? I did line the pan with heat resistant material...
