So I was wondering if anyone has ever fitted a race style tail to a 1090 brutale. If so what fits? I have the standard 1090 with the one piece seat. So that might be my issue.
What kind of tail, do you have any example pics ? I have the single seat conversion on my 2015 Brutale, it just replaced the single seat. Maybe im mistaken, but I thought it was possible to replace the single piece seat with later 2 part or single with cover.
I think that is true. I have that stupid one piece one mine so I may have to convert to the double seat.I would love to put a race tail on and that might be the only way to do it
the conversion kit is not so expensive, then you just need front single seat (may find a used one on ebay) and rear seat cover colour matched to your bike . The colour matched seat cover is the most expensive part.
I Might look into that kit. But i was thinking like a race F4 tail on a brutale... But not sure if that will work
So get an F4 subframe and front hinge. Get a F4 tail and your are done.
475932
475933
475934
475935
The frame plates are the same between F4 and B4 so the parts should mount up
(The above statement (in bold) is under further evaluation...I think I screwed up here...)
The used market is your friend here for cost.
Good to know. I did not think that the subframes mounting points were the same. Thanks for the post! I want to do this but it might be a longer process to acquire all the parts.
Are all F4 subframes interchangeable with the b4?
@Theducman: This requires a bit more research. I screwed something up.
