1 - 3 of 3 Posts
I'm thinking mine is plugged or broken. I downloaded a parts manual but cant seem to find it to test.
Anybody have a picture or exact location/test procedures?
My tank wont vent and after riding the tank has very high vacuum in it.
I used high pressure air in the rear most hole with the black seal that mates up to the gas cap and air passed through, albeit not easily. I also pushed air backwards through the little hole in the cap and it blew out the seal in the cap!
Cap blockage? Or just too much pressure in the hose!
Maybe too much air pressure. What was line psi? 90~120? tank vent should pass air blown from your mouth easily....maybe 5 psi? It doesn't have to flow a lot of air.
There is a fuel separator labyrinth in the cap, the seal mates the cap to the internal hose in the tank that goes to your evap can.
Do a search on eliminating the evap system (your bike has same system as mine did). Pretty simple job, will provide a little bit more gas capacity in the tank, remove a little bit of weight, and eliminate a potential problem (overfilled tank resulting in contaminated canister).
DO NOT buy the TPO evap emissions system eliminator kit on eBay.
Yep! Line pressure was 110 but I only gave the little black seal on the tank a short little blast. Tiny blast popped the seal on the cap though!
I'll look for the evap removal thread!
edit: found it! evap canister removal
Guess I need to order a new pump O ring and some vac caps!
1 - 3 of 3 Posts
