1 - 6 of 6 Posts
Jen returned on her R the other day and pointed out a white smear al down the LHS of the bike. Got it on the bench for a look and here are the results.
Thinking the radiator, it failed once before and which was a warranty repair 3 years ago. Certainly a weak point of this model I think. Letting it cool down and the strip shall begin.
Discussion Starter · #3 ·
Hi Joe,
The warranty replacement radiator was the one with the improved, beefed up bracket, funny how it has fractured in the same place.
Yes I will get it repaired, or maybe solder it myself. I have heard a lot of people use JB Weld or similar.
Your bracket looks a good idea Joe, I shall start saving my pennies.:laughing:
jimboF4
Hi Joe,
jimboF4
Ha ha Jim...You should be in the naughty boy corner for not fitting one already...200 - F4 riders cannot be wrong ..
I know Jim..it's just been Christmas and time's are hard lol...I'll send you a pm :)
joe
Discussion Starter · #5 ·
Pulled the top radiator, my goodness how can a bike get so filthy and the rad that battered in three years. I will post a picture later of how tatty it all is. Think I have the split identified will try a home pressure leak test tomorrow. Then break out the liquid metal epoxy.
jimboF4
it's just a stupid way to mount a radiator...... from the weakest part
it should be supported by the strongest point, the bottom of the joint between the tanks and the core end caps
like on Fords.....they use 4 identical rubber pieces that fit the radiator the bottom 2 lie in the frame and support the radiator the top 2 hold the radiator down with 2 brackets
2 bolts
2 brackets
4 pieces of rubber
doesn't get any simpler or stronger
:drummer:
1 - 6 of 6 Posts
