1 - 20 of 70 Posts
F4 1’ gen 750 ....
Well :
Bike purchased
Km?22.000
Price not bad...
I’ve started dismantling it
Done air filter new
Done cleaning of carburators- air intake...
Now it’s yet better now next steps
Sparks replacement
Fuel replacement
Original exhaust f4 installing
Aaaaaa i’ve Found 🤔🤔🤔a not original eprom...
My target is: an original f4 tuned for a little more cv&torque....
Any suggestions? To modify std f4 arrow exhaust?looking to reach the target?.
479252
I would replace the fuel lines in the tank and the fuel filter.
Check with Merc07 (Adam)about the eprom... That one may have a custom map that will make the bike perform better than the original. The original is optimized for emissions...not actual performance.
Reactions: Lingegner
Looks like a B4 to me .. ??
The B4 is the Brutale upright series naked bike.
The F4 is the leaned forward "crotch rocket".
Looking at the tank and other parts in the images, that's a Brutale you have; not an F4. Both models below.
479321
479322
Discussion Starter · #12 ·
Naaaa let me explain i’ve Checked frame number and it’s a f4 old that has been turned in a brutale not a brutale .... but i’m Trying to understand from vin numbers colour and version
Thanks 😁
Discussion Starter · #13 ·
My target is to turn it back in a f4 .... i’m Fighting with my mind... all original except for cpu & Cv or full carbon ???
Yep! You need to do some thinking there -- You will spend a lot of money turning it back in to an "original F4" -- And unless it is a "limited" or "Special" from the Vin number, What you will have is an "original F4 750" There's quite a lot of those around, even if it is still rare compared to even "specials" from Honda, Kwaka or Suzuki .. If I were at the stage you are, I would build my own "special" - I'm fairly certain you could do a full carbon kit, tank,airbox etc. for what you would have to pay for the parts to make it truly "original" -
Reactions: Tink
It's a blank canvas, which is pretty awesome. Also it's not gonna be thaaat much money - airbox, fairings, headlight and mounts and ducts? I'm pretty certain there are far more liter bikes than there are 750s running around.
Discussion Starter · #17 ·
🤔🤔🤔🤔this is my second mv first one was a f4 evo 2.
Now.... i’m Finishing to restore a r1 of 1998 first serie white....finished the r1 the target is ... starting from November sell all brutale parts installed & turn it in a lighter & fantastic & personalized f4 carbon & gold....+ maintenance of suspension ....
My gurus of mv world i’m Purchasing original f4 exhaust...
Is it possible to install them under brutale back ?
Does anybody know modifications to give to std exhaust more performance?.
Even modifying them internally like rg3?.
Suggestions accepted 🙃😁🙃😁🙃
479415
479416
I know that the F4 exhaust has been mounted to a B4, um, before....
In the attached pictures, you can see the major difference between the F4 (1st pic) and the B4 (3rd pic) subframe.
The mounting points are pointed out by the read arrow and the green arrow indicates where the "dogbone" hangers come through.
479421
479422
479423
1 - 20 of 70 Posts
