1 - 6 of 6 Posts
When starting my 1000r the starter turns over a few times and seems to disengage. At first I thought it was the battery as it was 6 years old so I changed it but the symptom is still present. The starter turns over quickly but just stops. The engine will eventually start after a few prods and hasn't let me down, but I am worried it will leave me stranded. Any advice gratefully received. Cheers, Tont
Sent from Motorcycle.com App
I think the starter motors are a bit weak in them because they are so small. My starter motor gave up on my 2009 F4, with only 4000k's on the bike. When I pulled it apart, all four internal magnets had come loose from their glue.
glued magnets?
glued magnets??????
for a 100 years they bolted the magnets in, then some fuckwad in accounting heard about glue.....
Hey, its cheaper......than a screw, but when the glue fails......
bump start or walk common BMW R bike problem
stupid wankers:jerkoff::jerkoff::jerkoff::jerkoff:
glued magnets??????
Tell it like it is Noel :naughty:
If you'd like a starter motor to try to check yours is ko'd or ok let me know...also a starter solenoid too first check ..I got one of those too ..
Wellesbourne ; ) ?
joe
1 - 6 of 6 Posts
