1 - 2 of 2 Posts
'06 MV F4 front axle removal question
Hi,
in the process of swapping wheels. Any trick to remove the front axle spindle? is it right hand threaded? so far it is a bit tighter than I expected and did not want to crank on it if I am not doing something right.
TIA
Front Wheel removal process:
1.- Remove calipers screws (To slacken left hand as normally) and remove the calipers.
2.- Just slacken screws under the rigth front fork unit (left hand as normally).
3.- Slacken the front axel to the left hand (just the rear wheel nut must be removed slackening to the "rigth hand"). All screws has a torque yellow mark, try to keep always this rule.
4.- Put your foot under the wheel before the final axel removal and get the wheel.
That´s all.
1 - 2 of 2 Posts
