Oil crush washers
1 reading
2.7K views 3 replies 4 participants last post by  falcn
#1 ·
Anyone have a source for aftermarket oil plug crush washers? It’s a different size than my Ducati. What size I is it? I wonder how many other models the same washer would fit?
#2 ·
Head to your local auto parts store. Nothing special there. Readily available. Take the old one with you.
And please don't make multiple posts with the same question.
#4 ·
When I look up my 990r on the online fiches they list the size in the description:
28mm OD, 22.3mm ID, 1mm thick
So it looks like this should work as well.
Ducati oil drain plug gasket; Alu 28×22.5×1 22032083A
