MVAgusta.net
-   F4 - 1st Gen. 1998-2009 (https://www.mvagusta.net/forum/12-f4-1st-gen-1998-2009/)
-   -   Question ECU/Powercommander/Chips what am I to do? (https://www.mvagusta.net/forum/12-f4-1st-gen-1998-2009/7771-question-ecu-powercommander-chips-what-am-i-do.html)
R1andrew 04-11-2007 11:46 AM
With the F4R. Can I go with a power commander or do I need something else if I switch out the exhaust and go with future mods? I think I have seen where some poeple are using both. Power commander is much cheaper than the ECU. What are the pros and cons of both.
Thanks Andrew
RobP 04-11-2007 11:49 AM
Start with the RG3 ecu, youll be happy. You can't do the chip and there isn't a PC3 for the R yet.
FSL 04-11-2007 11:50 AM
Race/Rg3 ECU samething that what you need.
R1andrew 04-11-2007 12:02 PM
Thanks guys. What are the places where I can get this. I know emoto carries these. Any suppliers in the states?
FSL 04-11-2007 12:15 PM
Only place I know is Emoto. This item is in high demand and always backordered if you order today you will be lucky to get it in a month.Talk to Emoto.
tubsy 250 04-11-2007 05:31 PM
Thanks Andrew
got the race ecu on mine massive improvement but still runs a tad rich at the top end so still could be improved with a pc111 i will get the pc111 as well
airfuel 04-11-2007 05:46 PM
PC for the R is the same as all the others. they work fine. Just did a a new Senna yesterday. The only thing that is needed is a software patch that corrects the double rpm issue.
Copyright ©2000 - 2020, vBulletin Solutions, Inc.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
User Alert System provided by Advanced User Tagging (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
