MVAgusta.net
-   F4 - 2nd Gen. 2010+ (https://www.mvagusta.net/forum/106-f4-2nd-gen-2010/)
-   -   How difficult is it to remove and clean the fuel injectors on a 2010 F4? (https://www.mvagusta.net/forum/106-f4-2nd-gen-2010/53810-how-difficult-remove-clean-fuel-injectors-2010-f4.html)
Sequim-MVF4 06-02-2013 10:29 PM
Bike is lurching and stalls sometimes at idle.
theknurl 06-03-2013 11:54 PM
removing injectors?
Sequim-MVF4;
remove the tank
remove the fuel rail.....try to keep the injectors in the throttle bodies....if they stick it the fuel rail, GENTLY pull on the body of the injector to remove it from the fuel rail
DO NOT BEND OR PULL ON THE WIRES CONNECTED TO THE INJECTORS OR THE PLUGS
now with your thumb, press down on the wire clip on the top of the injector plug, where the curved cutout is......if the clip is on upside down, hooks on top, remove it with your fingernail...now remove the plug....and the injector
cleaning them is a job for a professional
i use RCEngineering, Gramps invented the testing machines and taught Honda how to inject cars
http://www.rceng.com/Fuel-Injector-Cleaning-P43C0.aspx
Gramps went fast too.....
http://www.motorcyclemuseum.org/hall...s/Collins1.jpg
Sorcerer was just a great bike.....and i was lucky enough to get to work on it too:drummer:
trickydicky 06-04-2013 02:57 PM
Originally Posted by theknurl (Post 611869)
Sequim-MVF4;
remove the tank
I made an Injector cleaner from a Gunsons Easybleed used on my Duc 916 injectors. Worked a treat on them.
theknurl 06-04-2013 10:44 PM
yes, you cleaned them.....
did you check the spray pattern?
how about the flow rate on a test bench, to 0.5%?
thats why i send them to RC:drummer:
