MVAgusta.net
-   F4 - 1st Gen. 1998-2009 (https://www.mvagusta.net/forum/12-f4-1st-gen-1998-2009/)
-   -   Fork disassembly (https://www.mvagusta.net/forum/12-f4-1st-gen-1998-2009/25304-fork-disassembly.html)
cooper3309 08-07-2009 10:54 PM
Fork disassembly
I need some help ! I have to disassemble my Showas on my F4 to change out the compression (i think thats what it is) piece on the tops of my forks. I tried lifting the bike and removing the pressure on the front tire and unscrewing the tops to remove them but they only unscrew so far :wtf:. It's been a long time since I had a pair of forks apart and I'm drawing a blank. I thought that by removing the tops the spring would loose tension and you should be able to remove the guts. There should be a hollow rod that runs the entire legnth to move oil with the spring around it. What am I doing wrong ? Any takers ???? Carl... Ed... Chris...
Coop
The_castle 08-08-2009 01:08 AM
1 Attachment(s)
Well I've spoken to Scooter about this and he reliably informs me, having consulted the manual, that the only reason that the top of the fork will not come off is that you may be undoing the preload adjuster.
Scooter is pointing to the large red fork cap that you need to remove. The smaller silver nut in the middle of the red cap is the preload adjuster.
I told Scooter that this is most likely not the case but he seemed adamant that the red cap should come right out when the fork is removed from the triple clamps.
F41NXS 08-08-2009 01:11 AM
Bloody hell mate
that scooter is one clever mutt!
cooper3309 08-08-2009 01:35 AM
Oh damn....... I shoulda known :wtf: I'm trying to remove the red cap from the rest of the fork internals. Any ideas ? When I lift it (cap) up theres a blue nut underneath it that it clearly unscrews from BUT there are these small pins dropping down from the top that surround the blue nut and I can't seem to get in there to disconnect the two
The_castle 08-08-2009 01:51 AM
Can you post a picture of your progress?
number2 08-08-2009 07:50 AM
Get a shop manual if you don't have one.
Copyright ©2000 - 2020, vBulletin Solutions, Inc.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
User Alert System provided by Advanced User Tagging (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
