MVAgusta.net
-   Maintenance & Tech. Issues (3 Cyl. Models) (https://www.mvagusta.net/forum/129-maintenance-tech-issues-3-cyl-models/)
-   -   F3 Front sprocket locking tab washer (https://www.mvagusta.net/forum/129-maintenance-tech-issues-3-cyl-models/244697-f3-front-sprocket-locking-tab-washer.html)
jaramharamharam 10-17-2019 01:10 PM
1 Attachment(s)
Is it ok to flatten it out, then re-bend after installing a sprocket?
No need to put a new one in if installing a new sprocket?
Part #40:
https://shop.startwintrading.com/en/...or-assembly-31
And while we are on the topic, does it really need to be bent for the nut to stay in place?? Seems like such a janky solution...
Thanks guys.
Black_Gold_Saw 10-17-2019 01:23 PM
You can unbend it and reuse it.
Just bend over another part, not the same.
jdgun 10-17-2019 01:39 PM
its just a safety precaution, as you are not using Loctite.
esq'z me 10-17-2019 05:17 PM
You will surprised at how quickly it will come loose without the tab lock.... trust me on this one. That shaft has a lot of inertial loads that will overcome even loc-tite.
jaramharamharam 10-18-2019 09:55 AM
Wow! Thats so scary! Thanks for the tips.
Mario Landavoz 10-18-2019 08:55 PM
The bent washer method of locking a nut is decades old and works as good as, or better than anything. "Janky" is is not.
