MVAgusta.net
-   Customising and Performance Section (https://www.mvagusta.net/forum/21-customising-performance-section/)
-   -   Could a piggyback fix my ECU? (https://www.mvagusta.net/forum/21-customising-performance-section/243499-could-piggyback-fix-my-ecu.html)
Barboy2 07-28-2019 04:43 PM
I have a supposedly faulty ECU on my Brutale 1090 r 2011 (AIW 5SM from Magneti Morelli). Could a piggyback fix the fact that I'm not receiving a signal to my coil (my coil is ok)?
Thanks in advance!
esq'z me 07-28-2019 05:22 PM
No...The piggyback units only modify signals coming from the ECU....No signal? No modification.
And they mostly only work on injectors, not ignition,
dansoarr 07-28-2019 05:24 PM
If your ecu is faulty then a piggy back wont help you. in general a piggyback is just that it sits on the back of your ecu and between the ancillaries and the ECU its self. It then overrides signals to ancillaries and feeds adjusted signals back to the ECU. If your ECU or any ancillaries are not working they still wont work.
If you have a faulty ECU, you either need a new ecu, fix yours or swap for a new system. sorry
number2 07-28-2019 07:19 PM
Ask Silentservice about having it repaired. He knows someone who might be able to help
Barboy2 07-29-2019 06:55 AM
thanks guys, just a thought :banghead:
bogie 07-30-2019 10:31 AM
This might help :)
https://www.mvagusta.net/forum/23-sa...le-1090rr.html
Barboy2 07-30-2019 03:19 PM
Originally Posted by bogie (Post 2590621)
Thanks but it's not the exact same part, 08E00B5568 for mine. But nice try :smile2:
