MVAgusta.net
-   Brutale B4 (https://www.mvagusta.net/forum/13-brutale-b4/)
-   -   Need help locating correct Oil Sump 910S (https://www.mvagusta.net/forum/13-brutale-b4/243115-need-help-locating-correct-oil-sump-910s.html)
Swoosht04 07-05-2019 10:45 AM
So my bike was leaning pretty bad and I noticed that it was being held with 2 bolts. 1 of which is stripped out, 1 has the housing cracked around it and the last one has the broken bolt inside of it. I need to replace it and found this on Ebay. It says 910R so I am not sure if it will fit my 2006 910S.
https://www.ebay.com/itm/MV-AGUSTA-B...kAAOSwr81UNV81
Anyone know?
silentservice703 07-05-2019 10:59 AM
It would help to know the year of your bike....and to have that information readily available in your signature line....
silentservice703 07-05-2019 11:05 AM
That being said, the 910S and the 910R have the same engine and therefore oil pan.
The part number for he pan is 80B092469 and the gasket is 800087786.
Edward 07-05-2019 11:12 AM
@silentservice703
@Swoosht04 see my signature below for a PSA regarding adding bike info...
silentservice703 07-05-2019 11:22 AM
Thanks @Edward....my eyes glossed right over that.
silentservice703 07-05-2019 11:28 AM
The part number is different for the 990 and the 1090RR.
The part number is the same for the 1078.
So, the listed item in EBay is probably correct.
esq'z me 07-05-2019 12:38 PM
I have one I will sell you if you prefer not to ship from overseas. Send me a PM
Swoosht04 07-05-2019 01:00 PM
Damn. I did it too quickly. I found one from a 2007 F4 1000R. I cross referenced the part numbers and they are the same. I got it from a breaker in Ohio. Should have it next week. I will be removing the exhaust, draining the rest of the oil and removing the oil pan. I have read that I should bypass the gasket and just use Hondabond or some other sealant for gaskets. Correct? Thanks guys.
Oh I added my bike to my sig.
esq'z me 07-05-2019 01:33 PM
That's good, hope you got a good price.
Yamabond #4, Suzukibond 1205B,.... lot's of good sealants out there designed for crankcase sealing without a gasket. Just don't use too much. It only takes a thin even film.
Swoosht04 07-05-2019 02:08 PM
100 bucks shipped. Is there a pattern when tightening the bolts? Or is it just criss cross? I found a thread somewhere that had the torque specs. Gonna have to do some more digging.
