Chain Noise on 675 f3
Hey guys,
Not sure if anyone has come across this before but my chain is making a lot of noise when you get off the throttle and back on. It really slaps up and down abruptly. I checked the chain slack which is spot on-is there another part that could be causing this? Any help would be greatly appreciated as I reside in Qatar and the main dealer is no more, its just a subsidiary of Harley Davidson. Cheers |
Assuming that you are not ham fisting the throttle which will obviously make some noise as abrupt changes will put quite a bit of stress on the chain.
How are the cush drive rubbers on the rear sprocket hub? How many km on the drive chain? I replaced mine at 12000km as it started having tight spots. Is your chain slack consistent throughout a full wheel revolution? |
I have not taken anything apart as I rely on my mechanic but his knowledge with Mv's is limited. I wouldn't say I was ham fisted, I noticed the noise when moving the bike in the car park (I normally ride with ear plugs in). I have not had the bike very long, might not be a bad idea to get a new chain and cush drive rubbers, I'm only in the country for another week. I do not have a paddock stand to check the chain condition while rotating. I would say the rubbers might take a bit of beating with heat in Qatar.
1. Usually ride with earplugs - this bike is mechanically noisy as is, earplugs hide a lot of that noise which you may find strange after going for a ride without them. 2. Parking lot - slowish parking lot speeds speeds tend to amplify chain rattle as there is some on-off throttle happening. Also some lugging of the engine could also be happening as most bikes have a tall 1st gear. 3. No paddock stand - you will probably only notice worn cush drive rubbers or a worn chain having the bike on a paddock stand. With that said, items 1 and 2 listed above are probably your culprits here and there is a good chance your bike is 100% fine. The mind is a powerful thing and once you notice something, its very difficult to un-notice. You can confirm if there is a real issue by putting it on a paddock stand and testing for chain tight spots by measuring the slack along a full wheel revolution. The cush drive you can check by turning the rear wheel a few degrees back and forth and noticing for any play at the sprocket before the chain starts to turn. This is most easily accomplished on a paddock stand, but you can check with a friend on the bike holding it straight and pushing it back and forth. |
Thanks fro your help, will replace the cush drive rubbers and see what happens.
vBulletin Security provided by
vBSecurity v2.2.2 (Pro) -
vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
User Alert System provided by
Advanced User Tagging (Pro) -
