MVAgusta.net
-   Maintenance & Tech. Issues (All 4 Cyl. Models) (https://www.mvagusta.net/forum/20-maintenance-tech-issues-all-4-cyl-models/)
-   -   MV Agusta F4 Valve Clearance Check Sheet (https://www.mvagusta.net/forum/20-maintenance-tech-issues-all-4-cyl-models/240953-mv-agusta-f4-valve-clearance-check-sheet.html)
stuarts7 02-06-2019 06:18 AM
1 Attachment(s)
Hi.
I have just checked and adjusted the valve clearances on my 2010 F4. I found that the sheet that was included in the maintenance manual was poorly compiled and could lead to confusion about which valve you were recording and adjusting. The positioning and numbering of the valve on the sheet is not relative to the position on the bike.
Attached is a sheet I have written myself which is much clearer and more intuitive. Set the bike as per the yellow setting and the yellow valves should be measured. Set the bike as per the green setting and the green valves should be measured.
You can print it to use it. Hope it is useful.
Stuart.
silentservice703 02-06-2019 06:25 AM
Good morning Stuart! Thanks for putting this together. Once "The Community" weighs in to validate what you have posted ( @theknurl @esq'z me) then we can make this a sticky!
esq'z me 02-06-2019 09:55 AM
It's a very nice chart.... I like the color coding part. Thanks for sharing.
I personally have no problems with the charts in the manuals...but then, it is just like the charts found in other brands manuals that I have been familiar with, and using, for decades.
EVO Chris 02-06-2019 10:00 AM
Excellent, thank Stuart.
theknurl 02-07-2019 06:51 PM
I just Xerox the one in the manual......
And use a Hi-liter pen:wink2:
Midnicrow 03-31-2019 03:13 PM
The one in the manual has all the valve numbers wrong.. See page 30 of the Chassis Manual for F4 1078
