MVAgusta.net
-   Brutale B3 and Dragster (https://www.mvagusta.net/forum/53-brutale-b3-dragster/)
-   -   Ram mounts Dragster RR (https://www.mvagusta.net/forum/53-brutale-b3-dragster/238429-ram-mounts-dragster-rr.html)
Atom 07-17-2018 05:57 PM
Looking for a good mounting system for my iPhone. Canít find anything that works with Dragster. Has anyone done this before? If so, what parts did you use?
Black_Gold_Saw 07-18-2018 09:11 AM
I honestly think your best solution would be to get a gascap mount and mount your GPS/phone onto that with a rammount.
What I used for my F3 are TECHMOUNT TECH 4G GRIPPER & TECHMOUNT TECHMOUNT EURO MOUNT 50MM 4-70050X
https://www.ebay.nl/itm/Techmount-De...cAAOSwMtxXsb8n
https://www.ebay.nl/itm/TECHMOUNT-TE...a15a0f2&_uhb=1
But looking at your handlebar and dashboard...that might not even work. Its so close together that it would probably block full steering.
Bruce Taylor 07-18-2018 04:47 PM
2 Attachment(s)
Bought two mounts, one for GoPro (Small ball) and another for a TomTom navigation system (Larger ball).
It was necessary to loosen the clutch lever and slide toward the centre.
The company in the UK is called RyderMount: https://ridermount.com/[/url]
Images are of the TomTom mount
M Squared 07-18-2018 05:37 PM
1 Attachment(s)
Hi Atom,
For my 2017 Dragster RC, I used RAM Ball mounts. Image attached / please see yellow arrows.
With kind regards,
M Squared
Bruce Taylor 07-19-2018 03:53 AM
But in that position will it not obscure the dash?
Also fitting a GoPro in that position you would be filming the speedo, which is not a wise move:frown2::frown2:
Mschwechter 07-19-2018 07:10 AM
There is a ram mount for the handle bar. Mount between clutch side switch and grip. Requires a little shaving on side to clear, but works well.
M Squared 07-19-2018 10:53 AM
1 Attachment(s)
Hi Bruce, Fortunately, my device (a combination GPS / Dash Cam phablet [detailed in another thread]) does not obscure the instrument cluster thanks to the stalks / arms chosen... plus the upright seating position of the Dragster lets me see over the device. The same applies to the 2nd RAM ball mount for the GoPro... a stalk / arm is used to position the lens to not record the instrument cluster. If you'd like, I could take another image while seated to show the relative positions. Take care / ride smart! M Squared
Bruce Taylor 07-19-2018 11:06 AM
Have to say from the attached photo that surprises me. Can you view all of the instrument information?
Awkward to access the key?
Bruce Taylor 07-19-2018 11:08 AM
See photo, that is what I have, no shaving required, just move the clutch assembly nearer to the centre
Atom 07-19-2018 03:54 PM
Thanks everyone for the posts but this is the exact setup I want to use. M Squared would you please post part numbers? I'm having a hell of a time locating the correct parts.
Copyright ©2000 - 2020, vBulletin Solutions, Inc.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
User Alert System provided by Advanced User Tagging (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
