MVAgusta.net
-   F4 - 1st Gen. 1998-2009 (https://www.mvagusta.net/forum/12-f4-1st-gen-1998-2009/)
-   -   MV drooling coolant in the cold......... (https://www.mvagusta.net/forum/12-f4-1st-gen-1998-2009/22562-mv-drooling-coolant-cold.html)
mrdon003 04-13-2009 09:47 PM
Has anybody had a problem that when you first start up you F4R when its below 45F that it dribbles some coolant out from the pump then its fine, but when its above 45F it doesn't do it, only a couple tablespoons
Snohman 04-13-2009 11:20 PM
pressure test your coolant system.
it may be that the seals arn't closing up properly cause they become stiffer in the cold - same problem knocked a spaceship out of the sky - quick solution to that would be to tighten the hose clamps
does it leak at all when running hot (under pressure)?
timpants 04-13-2009 11:27 PM
I ride mine around in 38F weather a few times and it was fine.
Copyright ©2000 - 2020, vBulletin Solutions, Inc.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
User Alert System provided by Advanced User Tagging (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
