MVAgusta.net
-   F3 (https://www.mvagusta.net/forum/45-f3/)
-   -   Who has converted their F3 to GP shift and how (https://www.mvagusta.net/forum/45-f3/199001-who-has-converted-their-f3-gp-shift-how.html)
brent98rt 11-03-2016 01:51 PM
I want to go back to GP shift on my F3
All I can find is a CNC Racing GP shifter assy that allows you to use the factory "Pull" sensor.
CNC Racing makes a rearset were you can pick Road or GP but it doens't list if the sensor needs to be replaced and changed to a "Push" or if it uses the factory sensor.
If anyone has gone to GP, how did you do it? New sensor? old sensor?
Edit:
Found info on it. I need a reset like Sato makes. or a adaptor for the shifter. haven't heard anything back from CNC Racing
TheGodfather 11-03-2016 02:45 PM
If by GP you mean race shift, mine has just been done.
I have lightec rearsets and standard push QS on the F3. The QS rod was turned upside down and and moved to the other side of the rocker arm on the rearset.
Can take a pic if you need.
DesignCorse 11-03-2016 02:46 PM
Edit:
Hello Brent,
I would suggest looking at:
http://feelthetrack.com/testing-prog...shift-upgrade/
Hope it helps:)
dazo 11-03-2016 02:46 PM
I have the Lightech rearsets which allow you to attach the rod with the sensor in front of the shift lever pivot so that when I push down it actuates by pushing the shift rod with the sensor up.
I hope this makes some kind of sense.
brent98rt 11-03-2016 03:20 PM
Actually if you could, please take pic of it.
The QS sensor on my bike reads "pull"
TheGodfather 11-03-2016 03:22 PM
Hi Dazo. I'd be interested in a pic of your set up as we've got the same rearsets but set up differently. You are running race/gp shift ? As mine was set like yours and it was road shift.
Ducati23 11-03-2016 03:30 PM
The Woodcraft rearsets allow use of the stock QS sensor for Standard and GP shift. Front mount point is standard shift, rear mount point is GP shift.
https://photos.smugmug.com/MV-F3-Bui...O/IMG_0751.jpg
brent98rt 11-03-2016 04:24 PM
Could you post a pic of yours please?
brent98rt 11-03-2016 04:25 PM
Thank you.
Moriwaki 11-03-2016 05:15 PM
I use the MV Agusta Corse set (with stock quickshifter); like it very much.
Pretty sure it is manufactured by Valtermoto but they don't list it so only available from MV.
Link from the MV website:
http://www.mvagusta.com/en/discover-...reverso-f3-cp/
Copyright ©2000 - 2020, vBulletin Solutions, Inc.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
User Alert System provided by Advanced User Tagging (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
