MVAgusta.net
-   F4 - 2nd Gen. 2010+ (https://www.mvagusta.net/forum/106-f4-2nd-gen-2010/)
-   -   2013 f4RR or 2012 f4RR? (https://www.mvagusta.net/forum/106-f4-2nd-gen-2010/192778-2013-f4rr-2012-f4rr.html)
skitz0 09-06-2016 01:23 PM
hi im looking a replacement for my 848, i saw this gorgeous '12 and '13 F4RR. For '12 3000miles for $15,300 and for '13 8675miles for $16k. which do you think is better and anything i should know or do before i purchase it?? thanks....
ildar 09-06-2016 02:12 PM
2013. quick switching. electronic suspension module ecu upgrade program. abs
ARAMIS 09-06-2016 03:28 PM
If the color is the same that you lik I would go for the 2013. I also have one and is a fantastic bike;)
skitz0 09-06-2016 03:56 PM
any issue on '13 i should worry about? i really like mv but the problem is the nearest dealer here is like 200 miles away. thanks
:brutale:
Al- 09-06-2016 04:19 PM
2012 because I'm a retrogrouch and don't like the idea of electronic throttle bodies
midget81 09-06-2016 04:22 PM
+1
Fragile 09-06-2016 08:48 PM
My 14 is fabulous, although I don't know why my brake discs warped so soon at 8K miles, but it is now confirmed so. I guess just because it says Brembo doesn't mean it won't have issues.
Camberdually 09-07-2016 12:53 PM
I went through a similar decision with 2012 f4R and 2013 f4. I ended up going with the 13 strictly because of color. if you are really going to customize it I would go with the 12 if you are going to slap some bolt ons and enjoy it fairly stock go with the 13.
skitz0 09-07-2016 05:13 PM
Thanks guys!!!
Dahulk 09-09-2016 05:14 PM
4 Attachment(s)
I would add that 2012 was the last year before they went to fly by wire throttle and also change to eldor ECU. I have a 2012 F4RR and my friend had a 2013 F4. A few subtitle differences I have notice
- Almost no tension on 2013 F4 throttle compared to 2012 F4RR which I did not like
- Issues with sensor light for exhaust valve till he removed the whole assembly
- With the change of ECU the only option for a tuner was the rapid bike which was more expensive than the power commander.
- 2013 F4 had the quickshifter which I wish the 2012 had but I will add myself
- 2012 have the reqular Olins and not the adjustable electronics Olins shocks
- There seem to be more fuel map updates for 2013 Eldor ECU than 2012.
- I prefer the 2012 Colour Scheme better personally but that is my personal choice.
Hopefully my inputs help, either bike you choose I am sure you will be happy owning an MV. For me the 2012 I was able to map and fix some of the fueling issues cheaper than the 2013 fueling issues my friend experience. Not sure if fueling is still an issue as this was about a year ago.
