MVAgusta.net
-   Maintenance & Tech. Issues (3 Cyl. Models) (https://www.mvagusta.net/forum/129-maintenance-tech-issues-3-cyl-models/)
-   -   F3 lights stopped working (https://www.mvagusta.net/forum/129-maintenance-tech-issues-3-cyl-models/177298-f3-lights-stopped-working.html)
Dec_Tater 04-25-2016 11:23 AM
I tried changing the fuses and it wasn't that. Seems like it is though because the horn doesn't work either. The back light works but not the brake light. I can't find any wires touching in the indicators. looks like I have to take it to the stealership. Thanks
idahomike 04-25-2016 02:20 PM
As PT said, if you aren't blowing fuses, than it most likely is not a short but an open. Make sure the fuse is good with a meter, then reseat with dielectric grease. If no luck there, then more meter work is needed to see if power is available in the circuit.
PTsalas 04-26-2016 01:38 AM
I had a blown number plate bulb that one would immediately pop the new fuse I put in. Are the new fuses blowing after you put them in? Otherwise open circuit as said above.
