MVAgusta.net
-   F4 - 2nd Gen. 2010+ (https://www.mvagusta.net/forum/106-f4-2nd-gen-2010/)
-   -   missing part on throttle body! (https://www.mvagusta.net/forum/106-f4-2nd-gen-2010/111481-missing-part-throttle-body.html)
falzon75 08-26-2014 12:00 AM
1 Attachment(s)
How are you all, have a bit of a problem, out riding and bike started running rough as guts when taking off, and felt unbalanced like it was on 2 cylinders! Further inspection while checking plugs, coils etc I found I was missing the spring between the two throttle bodies! See image, just seeing if anyone has had this issue before and know what the fix is or where I can get this tiny part from? See the images, one is of my bike missing, other is of same but with the srping!
falzon75 08-26-2014 12:23 AM
1 Attachment(s)
Here is a pic showing missing spring!
theknurl 08-26-2014 12:29 AM
spring?
just ran across this problem on an RZ-350, same stupid Mikuni linkage
on the RZ there was nothing to locate one end of the spring.... there was a teat on one side but not the other...... I drilled and tapped it for a short screw and made a spring
in the RZ book the there is a warning "do not lose this spring"
probably not available:wtf::wtf::wtf:
falzon75 08-26-2014 12:49 AM
Does it need to be a spring or could I run a bolt and nut setup
theknurl 09-08-2014 08:54 PM
that will work, but drill and tap the far left piece in picture #1 post 2 and set it up like the opposing screw/spring
let the springs keep the screws in place...... tightening jamb nuts in there :jsm::jsm:
