MVAgusta.net
-   F4 - 2nd Gen. 2010+ (https://www.mvagusta.net/forum/106-f4-2nd-gen-2010/)
-   -   Quick Shifter Theory (https://www.mvagusta.net/forum/106-f4-2nd-gen-2010/102641-quick-shifter-theory.html)
flyboyk 06-23-2014 08:19 PM
Anyone able to find any information on how the 2013/14 Quickshift system is activated through the wire attached to the clamp bolt on the shift lever. Is it through tilt when the lever is moved?
BSR-1 06-23-2014 08:21 PM
It's always been kind of a mystery to me how a washer knows when you're shifting.
flyboyk 06-23-2014 09:34 PM
Exactly, know one seems to know!
Donsy 06-24-2014 12:20 AM
It's a strain gauge inside the mechanism, activated by the amount of pressure applied through the bolt, hard to explain, but it's not a tilt switch.
I do believe the bolt torque tension is quite important, so if you adjust the lever, make sure you get that right.
They've been around in various forms for a while.
flyboyk 06-24-2014 12:52 AM
Thanks, the next question is, what`s the correct torque? It could probably just need to detect any sort of strain from it`s stable state before the shift which would negate the need to get that bolt torqued to a very specific number.
BSR-1 06-24-2014 10:05 AM
If it's really as simple as detecting strain. I don't know why it doesn't cut ignition on downshift.
I mean can it really tell if it's being pushed up or down?
Obviously that wouldn't cause it to blip or rev match but why doesn't it cut ignition to initiate a shift?
LWX 06-24-2014 11:32 AM
1 Attachment(s)
See pic
Donsy 06-24-2014 11:34 AM
Ask your dealer or check the Workshop manual about torque settings, read up about strain gauge operation in other quick shifters, not all use the strain gauge method, some are just a switch. The pressure on the strain gauge determines how long the ignition is interrupted for.
Why do you need ignition cut on downshift, your throttle is closed, if you think it through you'll see what I mean:)
How many wires on the F4's unit?
It's not hard these days for software developers to write program's that use downshift auto blipping via quichshifter, It's been used in racing for some time.
BSR-1 06-24-2014 11:39 AM
I don't think I NEED it, I'm just curious. If the strain gauge is programmed to do it, how does it know if you pushing up or down?
Like you say it's not hard for them to do. So why doesn't the auto blip work on MV's? I mean on the "first ride" report in the magazines, over a year ago, they said it worked flawlessly.
Donsy 06-24-2014 12:02 PM
In it's own way it works like a double pole or two way switch, this I am assuming, the strain gauge I use have to be aught which way is upshifting, no swapping of wires.
I'll take a stab in the dark till somebody like Chris or Hans corrects me:
1. When the ECU see's a closed throttle position, then get's a pressure signal from the q/s, it can be programmed to do the right thing with the gas and your foot does the rest, using throttle position sensors etc.
When your hard on the gas and it pics up q/s pressure the ECU will do go the other way.
2. Or the way some other units do it (Honda I've worked on), will use a three wire switch (non strain gauge), push one way and pull the other way, send's a different signal (2-way switch).
I've heard of a few guys on the forum who's had the software updates and the downshift auto blip works just fine, another had to have the bolt replaced or re-torqued. I believe some don't care about using it. Best to hear from them, sorry mate, can't help any more than that.
Copyright ©2000 - 2020, vBulletin Solutions, Inc.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
User Alert System provided by Advanced User Tagging (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
