Power connection for Garmin 595 cradle? - MVAgusta.net
post #1 of 13 (permalink) Old 11-16-2019, 03:23 PM Thread Starter
So I have a question on where riders are pulling a switched 12v power supply for Garmins and other Nav units. On my Monster S and Triumph STR there are switched leads under the tanks for heated grip additions that Iíve wired the cradles into for power (and I run the USB and headphone/mic leads under the seat for future use I guess... have never really used these extra connectors). On the TV there is a 12v power port for accessories on the riderís right side that Iíll likely tap into. I just wanted to ask if this is a switched lead or always-on feed (have been traveling and havenít had much time to piddle lately with it). This seems like a good location for a connection for the cradle.
I also hope there is some room under the front fairing to hide all the extra cables that come with this cradle. One thing I may do is pull the USB link to one of the little compartments up in the sides of the fairing... would allow me to put a USB drive full of MP3s there if anything else (since thereís no room under the pillion seat to speak of).
Iíll update everyone with pics/install once I get going next week. TIA for any feedback.
Hal.
hpc3 is offline
post #2 of 13 (permalink) Old 11-16-2019, 03:42 PM
Allworld's Avatar
I have 2 USB connections in the front, which you can attach your Garmin to and disconnect it when you want, no hard wiring required.
Bikes:
2015 Triumph Street Triple R
Allworld is offline
post #3 of 13 (permalink) Old 11-16-2019, 05:29 PM Thread Starter
I believe the USBs are 5v
The Garmin cradle needs 12v iirc.
hpc3 is offline
post #4 of 13 (permalink) Old 11-17-2019, 04:48 AM
MarcSilverTriple's Avatar
Originally Posted by hpc3 View Post
So I have a question on where riders are pulling a switched 12v power supply for Garmins and other Nav units. On my Monster S and Triumph STR there are switched leads under the tanks for heated grip additions that I’ve wired the cradles into for power (and I run the USB and headphone/mic leads under the seat for future use I guess... have never really used these extra connectors). On the TV there is a 12v power port for accessories on the rider’s right side that I’ll likely tap into. I just wanted to ask if this is a switched lead or always-on feed (have been traveling and haven’t had much time to piddle lately with it). This seems like a good location for a connection for the cradle.
I also hope there is some room under the front fairing to hide all the extra cables that come with this cradle. One thing I may do is pull the USB link to one of the little compartments up in the sides of the fairing... would allow me to put a USB drive full of MP3s there if anything else (since there’s no room under the pillion seat to speak of).
I’ll update everyone with pics/install once I get going next week. TIA for any feedback.
Hal.
All Turismo Veloce got a 12V feed plug available for the GPS option somewhere in the harness on the right side. You are likely to have to remove the right and left fairing and the cone nose to access it. My assumption is that it should be somewhere on the right side encased within the harness… (all is closed using rubers that can be opened and closed again. You'll have to search.
By the way: all the 12V socket, feed plugs, and USB socket are actually switched ones
Marc,
Turismo Veloce in France
MarcSilverTriple is online now
post #5 of 13 (permalink) Old 11-17-2019, 07:41 AM
Bumpkin's Avatar
I brought a Hella 90ļ plug which works well with this socket, the flip up cover on the socket practically secures the plug in place.
I hate having excess unnecessary coils of cable. I'm guessing that the cradle is the same as for my Zumo 590. I just measured how long I needed, with a bit of slack, and cut the Garmin cable to length, pared back and insulated all but the black and red wires. Wired red to to centre, black to edge of the plug, threaded this through and tied to existing wiring with Velcro ties. Worked like a charm for my 2 and bit years/18,000 miles with the bike and is easily removable should that be necessary. Length of cable was thankfully enough to wire to the dedicated connection on my current bike, though new cradles are available at reasonable cost.
Chas
Bumpkin is offline
post #6 of 13 (permalink) Old 11-17-2019, 08:39 AM
It is easy enough to figure out if your 12V port is switched...measure voltage with the key on and key off.
post #7 of 13 (permalink) Old 11-18-2019, 09:13 AM Thread Starter
Agreed. Now that I'm home I'll put a meter on it today and update back with findings. Thanks.
hpc3 is offline
post #8 of 13 (permalink) Old 11-18-2019, 09:16 AM Thread Starter
Thanks Marc
Originally Posted by MarcSilverTriple View Post
All Turismo Veloce got a 12V feed plug available for the GPS option somewhere in the harness on the right side. You are likely to have to remove the right and left fairing and the cone nose to access it. My assumption is that it should be somewhere on the right side encased within the harnessÖ (all is closed using rubers that can be opened and closed again. You'll have to search.
I figured there may be an accessory plug or lead somewhere. I think I have a wiring diagram fo the 2016 TV here, will review that before taking things apart. Worst case I can wire to the heat/accessory plug on the right (provided its a switched feed). Appreciate the help.
hpc3 is offline
post #9 of 13 (permalink) Old 11-18-2019, 03:25 PM
My Zumo GPS is relying on the standard GPS option socket.
For the worst case, please take note : heat/accessories plug and usb are switched. And in the case you need more feeds : I did use the signal of the rear socket to switch on an additional fuse box (mounted under a low profile lithium ion battery (which use less room than the standard Acid Gel battery)) where I have my additional lights, voltmeter, power feed for the GIVI tank bag and the CLS Evo plugged in.
Marc,
post #10 of 13 (permalink) Old 11-18-2019, 04:17 PM Thread Starter
So Marc is there a plug for the factory GPS?
That would be ideal if so... you wouldn't happen to have a pic of its location or idea of where it's located would you? Appreciate all the help.
hpc3 is offline
