Cruise control ? - MVAgusta.net
 4Likes
post #1 of 15 (permalink) Old 10-06-2019, 07:15 AM Thread Starter
Jigsaw312rr's Avatar
Cruise control ?
Can anyone tell me if the cruise control is supposed to cut out when leaning into a corner? At 110kph on sweeping bends it has done it 3 times now, it's a bit scary.
__________________
Geoff
"Happiness is just an illusion, caused by the temporary absence of reality"
2015 Turismo Veloce
2013 KTM1190 EDS(sold
2014 BMW R9t
2009 Honda VFR1200(sold)
2009 F4 1078 312RR(sold)
2005 Triumph Daytona 955(sold)
1970 Kawasaki 350 Mach1(sold)
1960 BSA Bantam(sold)
Jigsaw312rr is online now
post #2 of 15 (permalink) Old 10-06-2019, 11:29 AM
Edward's Avatar
Greetings Geoff,
Have a quick read... general discussion about CC and such.
I don't have such fancy controls but what I've learned via thread is if you engage your clutch or brake it disengages CC. That's very probable on a curve even if its sweeping.
https://www.mvagusta.net/forum/74-tu...nt-engage.html
2008 B4 910s. . . .
1987 BMW K75s. . . .
PSA/Public Service Announcement W e l c o m e !
(Forum Introduction Thread)
Adding LOCATION to your profile: Tools > User CP > Your Profile > Edit Your details > Additional Information > Location
Adding BIKE YEAR and MODEL/s to your signature: Tools > User CP > Settings & Options > Edit Signature
(Special thanks to forum member Donsy)
Edward is online now
post #3 of 15 (permalink) Old 10-06-2019, 11:52 AM
Figifister's Avatar
I had not noticed this....how far are you leaning? Im assuming you are riding through fast long sweepers? There might be a lean angle sensor that cuts cruise based on degree of angle.
Maybe you hit a bump and traction control cut in. What setting do you set your TC to?
On my TV the only things that cut CC are downshifting, and front brake engagement.
Sent from my SM-G930V using Tapatalk
Figifister is offline
post #4 of 15 (permalink) Old 10-06-2019, 03:25 PM
Teeps's Avatar
My '06 TV does the same.
But it does seem more sensitive (less lean angle) when going left than to the right.
2016 Turismo Veloce 800
Teeps is offline
post #5 of 15 (permalink) Old 10-06-2019, 04:33 PM
telemark's Avatar
Not had this problem with mine, but I never engaged cruise control on bends that the lean angle would be an issue. However, Cruise control is only allowed in 6th gear (which is my biggest gripe) so at 110km the revs are fairly low, maybe it's a combination of factors. For me to engage cruise control at a reasonable speed and revs I'd lose my licence, most roads are 90km max. I don't know why they can't allow you to engage cruise in say 3rd or 4th gear once over a minimum speed.
Sent from my iPad using Tapatalk
Figifister likes this.
telemark is offline
post #6 of 15 (permalink) Old 10-06-2019, 06:47 PM Thread Starter
Thanks guys, this happens only on right lean angle without touching any controls, @Figifister you may be right about a lean angle sensor? And also discovered that you can disengage CC buy just putting pressure under the gear lever and pushing up. Traction control is on 8, never played with it.
__________________
Geoff
2015 Turismo Veloce
2014 BMW R9t
post #7 of 15 (permalink) Old 10-06-2019, 07:27 PM
Figifister's Avatar
On 8!! Holy crap turn it off! Just to see how much faster the bike is...oh and to se if it solves your problem. Haha
8 is so intrusive. I ride on 4 unless I'm racing someone.
I would bet money it's your traction control but just try that first to se.
You haven't lived if you've only rode it on 8!
Teeps, Terrys409 and nigelrb like this.
post #8 of 15 (permalink) Old 10-07-2019, 01:53 AM Thread Starter
Cheers mate, Will try tonight.
__________________
Geoff
2015 Turismo Veloce
2014 BMW R9t
post #9 of 15 (permalink) Old 10-08-2019, 12:33 AM Thread Starter
So, it seems like it was the traction control cutting in on the corners. Set on 3 and have not had it happen again, still, I think it's a dangerous situation to have a sudden loss of power mid-corner safety device or not.
__________________
Geoff
2015 Turismo Veloce
2014 BMW R9t
post #10 of 15 (permalink) Old 10-08-2019, 07:15 AM
Figifister's Avatar
Great!
You may post new threads
You may post replies
