I still love my bike right guys? - MVAgusta.net
 7Likes
post #1 of 33 (permalink) Old 08-16-2019, 08:06 PM Thread Starter
Figifister's Avatar
I swear. If one more thing breaks...... How does a 1/4in thick piece of steel break!?!? I mean come on. And to top it off the hex bolt is stripped before I even tried to loosen it...
Sent from my SM-G930V using Tapatalk
Figifister is offline
post #2 of 33 (permalink) Old 08-16-2019, 08:25 PM
Allworld's Avatar
That is a good question, one that MV should answer.
Bikes:
2015 Triumph Street Triple R
Allworld is online now
post #3 of 33 (permalink) Old 08-16-2019, 09:11 PM Thread Starter
Figifister's Avatar
"It's not in warrantee" says MV Agusta. That's the famous catch all phrase...
Even new Ferrari's come with a 7 YEAR warranty. Sigh...
post #4 of 33 (permalink) Old 08-16-2019, 11:56 PM
Deano's Avatar
Vibration will snap anything. Rubber mount it.
Deano
Mario Landavoz and XPARAUK like this.
2009 1078RR Brutale
Deano is offline
post #5 of 33 (permalink) Old 08-17-2019, 05:14 AM
Arcimboldo's Avatar
Thumbs down
The MV Agusta Service Bulletins is stone cold dead right now
BUT
Originally Posted by Figifister View Post
"It's not in warrantee" says MV Agusta....
The rear shock knob breakable arm was a recall bulletin item.
Should have been fixed before delivery.
Might have missed your bike.
MV had also a recall bulletin asking the dealer to fix the nut holding the windschield
My windshield went after less than 50 miles.
TV not rideable with a flapping windshield.
Had to remove the dashboard on the side of a crowded freeway.
The (big) nut was jumping around on top of the ribbed headlight housing.
Washer gone.
Leatherman rules,
fixed it on the spot.
Went back to the dealer because I'd lost one of the dashboard screws,
and my screwdriver bit,
maybe in the tall grass.
Checked the bulletins
found they hadn't replaced the breakable shock grip arm either.
Dragster
Arcimboldo is offline
post #6 of 33 (permalink) Old 08-17-2019, 08:30 AM
MV had also a recall bulletin asking the dealer to fix the nut holding the windshield
A typical crappy dealer pre-delivery failure.....
@Figifister ... go raise hell with your selling dealer and make sure you let MV know about their ineptitude.
post #7 of 33 (permalink) Old 08-17-2019, 09:11 AM Thread Starter
Figifister's Avatar
BUT
Washer gone.
Leatherman rules,
Just to be clear, the metal bracket is what the recall is for? That is the arm your referring to? What is the fix? I'm leaning towards the idea of the rubber bushing but I would still need a new bracket.
Also my visor rattles as well...
My hand guard, color matched cover flew off a couple thousand miles ago while going 110mph. Is that a recall item?
I'm guessing a no recall was issued on the rear turn signals burning out aswell....
I know you said the site is down but anything else I should be aware of flying off or breaking?!?.... Besides the cush drive bushings...
post #8 of 33 (permalink) Old 08-17-2019, 09:32 AM
Edward's Avatar
Yea you still do! Moto life often isn't a turnkey situation. Imagine pre-internet!
E d w a r d B4910s08
PUBLIC SERVICE ANNOUNCEMENT
1.
(Forum Introduction Thread)
2. Include your LOCATION in your profile: Tools > User CP > Your Profile > Edit Your details > Additional Information > Location
3. Include your BIKE MODEL/S in your signature: Tools > User CP > Settings & Options > Edit Signature
4.
Special thanks to forum member Donsy
Edward is offline
post #9 of 33 (permalink) Old 08-17-2019, 11:22 AM
Arcimboldo's Avatar
Red face One stitch in time
New parts replace the breakable ones.
Didn't check what it was.
Tighten the 3 nuts
Watch out for the bespoke rubber + metal washers.
Nope
Only two little screws.
One half turn too much on one screw, breaks the plastic.
Water ingress and vibrations kill the circuit board.
Warranty item
Replaced no question asked.
Punch a very small hole at the bottom helps a lot with the water.
Blinker fluid and all that.
By mistake
the dealer gave me an hefty bill for the rear turn signal.
Two (2!) hours of work he wrote!
...site is down
If and when this server goes online again check for TV bulletins and have it done.
Before a slipper clutch and/or clutch sensor switch failure
they can ruin a good ride.
Having the fuel gauge go bad end of june might be a problem
because in august MV Agusta and the rest of Italy is closed.
Warranty alright but no parts.
Something wobbles replace.
Easy and very cheap fix
5 little rubber blocks, cost 5€
Dragster
post #10 of 33 (permalink) Old 08-17-2019, 11:52 AM
Fastspy's Avatar
Service Bulletin Service Bulletin - Technisches Rundschreiben - Circulaire Technique - Circular Tecnica
Date:: 21 July 2016
Object: shock absorber spring preload adjuster support plate substitution
Product: Turismo Veloce (all versions)
SEE ATTACHMENT
File Type: pdf 4294_Service Bulletin n° 169 - spring preload support TV.pdf (80.1 KB, 48 views)
2014 Husqvarna FE501
Fastspy is offline
