What Spare Parts? - MVAgusta.net
 4Likes
  • 1 Post By albymangled
  • 1 Post By Lorretto
  • 2 Post By Terrys409
post #1 of 9 (permalink) Old 03-16-2019, 06:48 PM Thread Starter
What Spare Parts?
A 2018 Turismo will be in my garage next week. Given the meager availability of readily accessible parts, what spares should I have on hand for the Spring/Summers riding season? What breaks the most or needs maintenance?
Scott916sps is offline
post #2 of 9 (permalink) Old 03-17-2019, 05:08 AM
zzaraxx's Avatar
Rear indicators, full box of those...
zzaraxx is offline
post #3 of 9 (permalink) Old 03-17-2019, 05:14 AM
nigelrb's Avatar
What a shame such a question need be asked of this prestigious marque
(No criticism of Scott because I understand the question is a valid component of summer season preparation.)
2007 MV F4 1000R / 2005 Aprilia RSV1000R Factory / 2005 Aprilia RS50
2004 CBR1000RR Fireblade / 2011 CBR1000RR Fireblade / 2018 CBR1000R Fireblade SP2
1985 Honda VF1000R / 1985 Honda NS400R
nigelrb is offline
post #4 of 9 (permalink) Old 03-17-2019, 06:20 AM
Just make sure you are on a first name basis with your spare parts guy at the local MV emporium...
(Hi Simon, thanks for the great job on my recent parts order from Italy..)
If the TV indicators are so shit just buy aftermarket when the first set break...why replace them with OG's if they are shite?
I went out and put a tank full of fuel through my F4 today and she lapped it up...my nearly 60 year old back and shoulders are talkin' to me about the 206kms though..
nigelrb likes this.
Currently in the shed...
2007 F4 312R Black / White / Red.
2012 HD FXDWG 103 Blue Flames
2013 Ducati Diavel Very Black Metallic
1981 Triumph T140 Bonneville Maroon / Cream.
1973 Yamaha CT3 175 chook chaser
Adelaide...Sarf-A-Straylia
albymangled is offline
post #5 of 9 (permalink) Old 03-17-2019, 01:10 PM
My bike is a 2016 TVL so YMMV
I drilled weep holes in the directionals - so far no failures
About to swap out the clutch basket [preventative] and pressure switch. Your 2018 may not have theses issues as parts were updated.
Sprag clutch may go south - so far so good on mine. Your 2018 may not have this as parts were updated
Fuel indicator sensor may go south - no issue with mine
OEM battery - no failure preventive upgrade to Earth-X 36C
Tires - didn't care for the Pirellis much happier with Road 5s
Wish list - a spare DL in a non-reporting jurisdiction - the bike really does like the upper range.
Fastspy likes this.
Lorretto is offline
post #6 of 9 (permalink) Old 03-19-2019, 07:28 AM
Terrys409's Avatar
None. Forget about it and ride.
esq'z me and Wonko The Sane like this.
Terrys409 is offline
post #7 of 9 (permalink) Old 03-20-2019, 11:02 PM
It seems like getting parts is a common problem. I've been waiting for a new rear indicator for 6 momnths! So I fitted a pair of Barracuda 'IDEA' lights instead. BTW they needed a 150 ohm shunt resistor (ea) to get the required current draw to correct the flash rate.
I'm thinking of writing a letter of complaint to MVA Italy.
cutloose is offline
post #8 of 9 (permalink) Old 03-21-2019, 03:22 AM
zzaraxx's Avatar
After i changed "few hundreds" of rear indicators (all in guarantee) i decided to open indicator to see what is the problem, so i cut clear plastic from housing because its one piece Main power supply wire is soldered very weak to a LED connections and due vibrations it cuts, so i put more soldering lead and problem fix, i did more than 10000km and no problem, BUT it doesn't look nice cause i use Sikaflex to connect clear plastic with black housing.
When i was on EICMA in November i saw company that makes those rear indicators for MV, on that moment nobody was there so i decided to come back later and talk to them but i couldn't find them anymore, sorry my bad
zzaraxx is offline
post #9 of 9 (permalink) Old 03-27-2019, 05:45 AM
Red800's Avatar
My experience, get another TV to bastardise to keep your one going, no end of issues here and 4-6 months wait on parts is nothing short of criminal.
Bruce
MY15
Edition1 Turismo
Red800 is online now
